jollygreengiant
posted on 3/8/07 at 04:32 PM |
OK hands up whos got one. IAC 2.5v6 omega
As per tittle really.
I have got to ask here, because you never know, one of you will have a good one laying around looking for a good home.
Idle Air Control valve.
For Vauxhall Omega 2.5 V6 Decamber 1995 (N reg).
Bosch part number : 0 280 140 516
Beer tokens available.
edit bit ... Also fitted to some volvo's (440, 460, 480) and some saab's
[Edited on 3/8/07 by jollygreengiant]
stevebubs
posted on 3/8/07 at 04:39 PM |
Has it really given up the ghost. Squirting copious amounts of carb cleaner into every every 6 months or so fixes mine....
jollygreengiant
posted on 3/8/07 at 05:12 PM |
I could live with it, BUT, its the wifes daily driver and an auto, once hot every time she takes her foot of the accelerator, it stalls.
stevebubs
posted on 3/8/07 at 05:45 PM |
wierd...initial symptoms mine gives out is it decides to rev to about 2k for about 20 secs when starting from cold.
omega 24 v6
posted on 3/8/07 at 06:35 PM |
I've got 2 here at the moment with that part no on them but I can't say for sure if they are serviceable. What I can say is that they came
from a 16v redtop engine and a 2ltr 8valve carlton engine so it looks like a very common part across the vauxhall range. I've a v6 meega as well
so I'd prefer to keep the parts sorry. just letting you know that there are lots out there.
adithorp
posted on 3/8/07 at 07:06 PM |
Clean it out with carb cleaner and clean the throttle butterfly and housing. Usually does the trick.
Adrian
