Pdlewis
| posted on 10/8/07 at 10:44 AM |
Wanted: Pinto fuel pump blank
Hello,
As above anyone got one theyd like to sell?
(before i find a fleebayer to sell me 1 )
Paul
mitch2b
| posted on 10/8/07 at 12:10 PM |
make one, its only a flat plate the same outline as the pumps foot?
Mitch
indykid
| posted on 10/8/07 at 03:15 PM |
i made mine out of some 2mm aluminium plate. you could quite happily do the same in steel if you wanted, the filing would just take a bit longer.
it doesn't need to be made of 6mm or anything like that, just run a bead of oil proof gasket sealant round the outside edge.
tom
caber
| posted on 10/8/07 at 05:07 PM |
I user an ofcut of 3mm steel plate put it in the vice with the thick fibre spacer from between the pump and block and shaped it very neatly with the
angry grinder and flap wheel. Holding the two bits together I drilled 8mm holes for the bolts and all done! I'll make you one, £20 Plus
P&P
Caber
