Adam
| posted on 9/9/07 at 08:42 PM |
Sierra Prop
Hi All,
I'm building a MK indy and bought a 1991 sierra ghia to strip and use it's parts. Well i took the prop up to MK to get modified only to be
told it's the wrong one. Has anyone got or know where i might get the right prop from.
Adam
ReMan
| posted on 9/9/07 at 08:46 PM |
2 wheel drive sierra
It needs to look like the ones pictures in the reply to your last post
Adam
| posted on 9/9/07 at 08:56 PM |
the car i took it off was a two wheel drive. I'm trying to source a used prop from a SIERRA becuase the cost a new one is too much
roadrunner
| posted on 9/9/07 at 09:42 PM |
You need one like this, £20 scrapyard.
  propshaft before
James
| posted on 10/9/07 at 11:31 AM |
- Muhammad Ali
Adam
| posted on 10/9/07 at 12:14 PM |
I know i posted befor ebut everyone have suggested new ones...best price i've got is 350quid! Point in this post was did anyone have one to
sell or know of anwhere that has a sierra prop.
Adam
andyace
| posted on 10/9/07 at 12:49 PM |
Adam
I got mine from gts (http://www.ekmpowershop5.com/ekmps/shops/gtstuning/index.asp) for about £125, its looks the biz and is powdercoated.
If you can't get hold of a prop I have one sitting in my garage, I live in Birmingham, however I work in Nottingham (3 miles off J26).
It's yours for free if you want to collect it.
[Edited on 10/9/07 by andyace]
ReMan
| posted on 10/9/07 at 07:20 PM |
Adam
How does your compare to the one in Roadrunners pic above?
That's what it should start out like.
MK can mod them for you so it looks like the one in the previos posts response . ie with a metal flange both ends rather than the big rubber donut
above.
If budget is tight, then I would do that.
HTH
Adam
| posted on 10/9/07 at 07:50 PM |
My prop is the longer one.... i took this pic at MK. The smaller one (Correct one) is a cutomers so i couldn't exchange. Apparently i
couldn't use mine cause i was using a bike engine.
ReMan
| posted on 10/9/07 at 09:35 PM |
Anyone else here know why the above can't be modded?
