Author: Subject: Source of rad hose joining pipes?
DaveFJ
posted on 13/9/07 at 09:20 AM Reply With Quote
Looking for some pipes to join rad hoses. Any suggestions other than paying a fortune for the sort offered by Samco etc ?
Would somehwere like plumbcentre stock something suitable?
sizes I need are (I beleive) 32mm and 38mm
cheers
Dave
stevec
posted on 13/9/07 at 09:25 AM Reply With Quote
Some here
RazMan
posted on 13/9/07 at 09:38 AM Reply With Quote
CBS made up some custom sized ones for me - nice job too Rescued attachment Heater tee.jpg
Raz
worX
posted on 13/9/07 at 09:50 AM Reply With Quote
I like the colour of your bedding Raz!!!!
DaveFJ
I thought that £5 plus postage was a bit much to be honest... I was hoping for a locost solution.... (they are that price from Rally Design)
Cheers anyway
Dave
iank
posted on 13/9/07 at 09:59 AM Reply With Quote
You could make your own, but you already contributed to the thread that tells you how.
http://www.locostbuilders.co.uk/viewthread.php?tid=36828
I'd guess you are after something like this but screwfix at least don't sell ones big enough for your application.
[Edited on 13/9/07 by iank]
Anonymous
DaveFJ
posted on 13/9/07 at 10:02 AM Reply With Quote
quite happy about making my own lips - just need a cheap source of tubing!
cheers
Dave
DarrenW
posted on 13/9/07 at 10:15 AM Reply With Quote
Mac#1 supplied mine.
will121
posted on 13/9/07 at 11:00 AM Reply With Quote
a cheeper option for joining 32mm tube ive used copper solder ring straight connectors (or Tee's) 28mm copper pipe fittings have an external diameter of about 31mm and 15mm ones will do for 5/8" pipework
posted on 13/9/07 at 11:46 AM Reply With Quote
Look under the bonnet of a Rover 75
posted on 13/9/07 at 01:03 PM Reply With Quote
Get down to B&Q and have a look at aerial mounting poles. Ally tube sold in straight lengths and 90deg bends. Not sure if you'd save a great deal over a supplier like CBS though.
I can vouch for the quality and service from CBS for these pipes too - quick, inexpensive and they work.
2b_pablo
posted on 13/9/07 at 01:35 PM Reply With Quote
http://stores.ebay.co.uk/Kettering-Koi-and-Ponds_Pond-Flexible-Hose-Fittings_W0QQcolZ4QQdirZ1QQfsubZ12QQftidZ2QQtZkm
I got a 32mm one for £3.70 all in. 38mm also available
[Edited on 13/9/07 by 2b_pablo]
DaveFJ
posted on 13/9/07 at 01:37 PM Reply With Quote
Aha!
Pond equipment! That looks promising ! I'm off to my local garden center to see what they have
Dave
2b_pablo
posted on 13/9/07 at 01:43 PM Reply With Quote
locost enough?
RazMan
posted on 13/9/07 at 02:06 PM Reply With Quote
LOL thats an old fleece!
.... anyway my sheets are made of leather
Raz
DaveFJ
posted on 13/9/07 at 08:58 PM Reply With Quote
Cheers 2b_pablo
I took myself off to SeaPets this evening (they do a lot of pond stuff) and got plastic 32mm hose joiners for £1.87 each! Finally something on this car I can claim was locost!
Dave
2b_pablo
posted on 14/9/07 at 07:33 AM Reply With Quote
hee hee no problem mate
stevebubs
posted on 15/9/07 at 10:28 AM Reply With Quote
Originally posted by DaveFJ
Cheers 2b_pablo
It's unlikely a pond will be subject to the same temperatures that an engine's cooling system will, so it may be worth testing them by boiling in a pan of water for 30 minutes or so to make sure they don't go soft / brittle...last thing you want on your maiden run is for the coolant to drain out...
stevebubs
posted on 15/9/07 at 10:29 AM Reply With Quote
PS for joiners etc, I tend to use Bryn @ Allyfab. He'll also make up custom joiners for not too much (e.g. 3 into 1 etc)
DaveFJ
posted on 17/9/09 at 12:33 PM Reply With Quote
To post a follow up to this.....
The Pond plastic joiner did a sterling job for 18 months.... then yesterday gave way in a spectacular fashion tearing appart and dumping all my fluid on the road.
should have scrimped on that bit i guess!
off out now to buy some proper ally joiners from walker rubber and plastics (expensice option but i need them in a hurry for stafford!)
Dave
wilkingj
posted on 17/9/09 at 03:11 PM Reply With Quote
Alloy TV pole and bends.
Bake the beads at the end to stop the clips sliding off under pressure.
Use an "Plumbeasy Oyster Plumbing Pliers" from B&Q (Not all stores stock them, so do a stock check)>
Just start the beads either side of the seam weld to prevent you ending up with a bead right on the weld.
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 19/9/09 at 11:39 AM Reply With Quote
i must have missed the post first time round but I wouldn't use pond stuff - low temp., low pressure in a car.
i bought my joiner from
autoperformanceonline
plus a lot of silicone hose stuff, yep it is expensive but I doubt I will need to ever replace it.
[Edited on 19/9/09 by 02GF74]
