posted on 22/9/07 at 12:26 PM |
Thick-wall aluminium tube
Anyone know if/where I can get some thick-wall aluminium tube, 44mm o.d. x 3mm or 4mm wall thickness? I can only find very thin-walled stuff.
I am trying to check the availability of materials before I decide on the design of a bike carb manifold. If I can't get what I want then
I'll probably have to make it out of steel. Aluminium would be nice though...
cheers,
posted on 22/9/07 at 12:30 PM |
I made my pipes out of solid bar , only because I had it and was too tight to buy any pipe
worX
posted on 22/9/07 at 12:31 PM |
I found these guys really helpful...
http://www.metalfast.co.uk/
posted on 22/9/07 at 12:42 PM |
Good suggestion! I'll give them a call on Monday. It looks like they stock 1.75" x 10SWG ali tube, which would be ideal.
Are they approachable for smallish bits? I'll be after 2 metres max, plus a bit of sheet for the backing plate.
[Edited on 22/9/07 by David Jenkins]
Confused but excited.
posted on 22/9/07 at 02:03 PM |
They do offcuts at dicounted prices.
May have just what you want.
oadamo
posted on 22/9/07 at 02:34 PM |
ive got some offcuts at work its 50mm dia but 5mm thick wall. i think theres about a meter.
adam
posted on 22/9/07 at 02:36 PM |
Adam, thanks for the offer but that'll be too big - I don't want to make too much work for myself!
The 1.75" tube I'm after should be a nice snug fit into the rubber coupling sleeves.
oadamo
posted on 22/9/07 at 02:46 PM |
you'll be back
adam
daviep
posted on 22/9/07 at 06:03 PM |
What size is aluminium scaffold pipe?
andrew-theasby
posted on 22/9/07 at 06:51 PM |
its close 48mm od 4mm wall the stuff ive measured up.
