jabbahutt
| posted on 24/9/07 at 07:18 AM |
can anyone help?
Morning
Wondered if anyone here could do me a small favour for beer tokens as I don't have either the proper kit, either that or lack the skill.
I need two M10 bolts approx 20mm long drilling through their length with a hole big enough to take two leads for indicators.
I tried using a normal drill and a vice and only succeded in knackering two bolts, I suspect a pillar drill or something would be more suitable.
Either that or has anyone used this method for securing indicator extensions for SVA and has 2 M10 bolts drilled that they no longer need.
Beer tokens waiting if anyone could assist I'd be very grateful.
Nigel
[Edited on 24/9/07 by jabbahutt]
blakep82
| posted on 24/9/07 at 07:32 AM |
can't help, sorry, but i don't think a pillar drill would be ideal here. someone with a lathe is what you're after
________________________
lsdweb
| posted on 24/9/07 at 07:54 AM |
Nigel
Could you use a length of ali tube with an appropriate thread cut onto it instead. This wouldn't be as solid as your drilled bolt and would
probably fall off just after you passed SVA...
Wyn
| posted on 24/9/07 at 08:03 AM |
I used the method described and drilled out 2 bolts using a pillar drill. You could do a lot worse than buy a cheap pillar drill from Machine Mart -
I paid ~£35 for mine. It's not great, but for light use it's fine and so much beter than trying to use a hand held drill.
If you get stuck I'll happily drill them out if you send me the bolts and let me know what size hole you need.
Nick
Phil.J
| posted on 24/9/07 at 08:10 AM |
If you are still stuck I'll do this for you for the cost of the postage.
John22000
| posted on 24/9/07 at 11:37 AM |
Nigel,
Pretty sure I still have the indicators I had on for SVA, I adapted these with some ally tube to stick out far enough. I will have a look tonight if
you want. If they are there you are welcome to them...
No idea how to put a picture here but there is an SVA'd and Registered image in my Archive that just about shows them.
John.
jabbahutt
| posted on 24/9/07 at 12:30 PM |
John
does the tube pictured take an M10 thread on indicators and an M10 bolt in the nose cone? If so then I'd be really grateful if you
wouldn't mind me using them. U2U me and we can sort something out, it would be a good excuse to pop over and have a good look around your car
Nigel
John22000
| posted on 24/9/07 at 08:30 PM |
Hi Nigel,
I've dug them out.....
Both ends are 10mm, nut at one end to attach the indicator, bolt at the othr end to fasten to the nosecone. Couple of pics in my archive.
Crude but effective.
U2U to follow in a bit.....
John.
dave r
| posted on 25/9/07 at 06:05 AM |
i have a cheap pillar drill if you want one for yourself!!
dave
