hobbsy
posted on 28/9/07 at 08:20 AM |
WTD: Couple of plugs from an R1 loom
I'm after the plug and socket that goes to the injectors, basically the same mating pair that a Powercommander fits into (i.e you unplug those
connectors then plug the two connectors from the PC3 M-F, F-M to the bike loom).
Just though someone might have a partial loom or for some reason might have cut these off?
Dusty
posted on 28/9/07 at 09:47 AM |
The bods at Dataspares do a big range of connectors from Japanese bikes, just in case you can't find them here.
Dataspares
hobbsy
posted on 28/9/07 at 10:27 AM |
That is a really useful site as these sorts of things are usually very hard to find. I'll have a look at lunch time to see if the ones I need
are there.
Should be cheaper than getting them from a loom unless someone already has one chopped into bits (unlikely).
