StevieB
posted on 21/10/07 at 06:53 PM |
Thick walled ali tube
I know this has been asked a million times, but I couldn't find anything through searching:
Does anyone know of a decent source of thick walled ali tube to make a linkage for my paddle shift - I assume to tap out to M8 it'll need to be
6mm or 7mm ID.
gordon
posted on 21/10/07 at 07:11 PM |
Hi steve
pop down to your local BQ can get solid ali tube m8 and you can drill and tap it its cheap to.
posted on 21/10/07 at 07:40 PM |
Would that be a round bar ? To tap to M8 you will need it to be 10mm round which sounds a bit large.
hearbear
posted on 21/10/07 at 07:45 PM |
Try and see if you have a metal superstore near you they only charge for what you need. http://www.metalsupermarkets.com/MSC-storefinder.aspx
3.9Ltr SSC Stylus should be fun
shortie
posted on 21/10/07 at 08:33 PM |
Steve,
I have some spare from when i did mine, how much do you need?? I ended up buying 5meters!
It;s proper thick walled ali tube which you can tap with 8mm thread.
Rich
