Author: Subject: Gear Knob
posted on 9/11/07 at 08:50 AM Reply With Quote
Gear Knob
Standard Sierra gear knob wanted for SVA purposes.
Mine is broken so no good.. anyone got one lying around I can have?
jake_truck
posted on 9/11/07 at 11:46 AM Reply With Quote
Hi Steve
Got one you can have, in newcastle.
Let me know if you want it. I would like to see your carbs and megajolt in exchange!!
John
wilkingj
posted on 9/11/07 at 01:37 PM Reply With Quote
Cheap gearknob...
Pool Ball is about £3-5, Gear knob in Half Frauds or similar type motoring shop is about £30
Drill hole in a Pool Ball
heat end of gearstick (cheapo gas blowlamp) and wipe with a hotmelt glue stick
Slip Ball onto then Gear lever,
Dont fill the hole in the ball with hot glue as the cold lever will set the glue before you get it fully on.
to get it off again, just heat the gear lever with the blowlamp..
Easy and SVA proof.
Mine's a 8 Ball just like Snuggs... But I dont have the kiddy size ball on the oil dipstick
Best Regards
Geoff
http://www.v8viento.co.uk
