| posted on 11/12/07 at 03:21 PM |
Coolant T piece.
I'm after a 32mm pipe with a 15ish take off for the bottom coolant line.
In either copper or aluminum to stop any rust getting into the system.
Does anyone have the equipment to make one or know where I can purchase one off the shelf?
Thanks,
| posted on 11/12/07 at 03:25 PM |
CBS will make one for you from aluminium.
Presumbly domestic copper pipe fittings are of the wrong size?
| posted on 11/12/07 at 03:31 PM |
CBS? who are they?
DarrenW
| posted on 11/12/07 at 03:38 PM |
Car builder solutions
| posted on 11/12/07 at 03:44 PM |
cbs
see p. 67 of catalogue
quote: Beaded 32mm and 38mm tubes 120mm long with TiG
welded, 15mm take-offs. For heater take-offs or header tank
feeds etc. 32mm #TEE3215
38mm #TEE3815
£20 each (£22.50 inc vat)
not exactly locost but you are desperate!
welderman
| posted on 11/12/07 at 04:11 PM |
couild make one from stainless but it would have a 10mm "T" off from 32 mm tube if that helps
£7.00 inc postage to your door.
Thank's, Joe
I don't stalk people
welderman
| posted on 11/12/07 at 04:12 PM |
bit like this but this is 25mm with 32 "T".
Thank's, Joe
Bluemoon
| posted on 11/12/07 at 04:28 PM |
Sounds like a 28mm plumbers solder ring copper T will do, with the extra pipe reduced to 15mm, I think this is a standard plumbing fitting.
Dan
[Edited on 11/12/07 by Bluemoon]
bob
| posted on 11/12/07 at 04:43 PM |
My bottom pipe T pice came from tiger, was about £20 ish with postage.
Its 32mm with two 19mm outlets, i chopped it in half as i wanted the 19mm outlets to go in different dirrections.
Also had the ends lathed so the jubilee clip gets a better bite.
bob
| posted on 11/12/07 at 04:44 PM |
original
stevebubs
| posted on 11/12/07 at 07:59 PM |
Allyfab made mine up
http://www.allyfab.co.uk/
