<<  1    2  >>
Author: Subject: Car engine wanted
andy_mullin
posted on 14/12/07 at 02:40 PM Reply With Quote
Car engine wanted
Hi All,
I have just bought a part built Sylva Striker off Dwyer, I now need a good engine.
The car will be used for track days and maybe auto testing, so it needs to be a car engine.
All my mates run Blade engines, so it would be nice to be able to keep up with them.
nitram38
posted on 14/12/07 at 02:45 PM Reply With Quote
If you want to keep up with a blade then fit a blade engine!
There are power to weight issues with car engines V bike, unless you start using turbos/superchargers etc
Acceleration is generally better in a bec
Jubal
posted on 14/12/07 at 03:08 PM Reply With Quote
I'm not so sure. I reckon a good handling, car with 160-200hp (depending on weight) is enough to stay with a blade. From experience I know a well driven R300 does not struggle too much to drive slowly away from an Indy Blade on track.
CaptainJosh
posted on 14/12/07 at 03:30 PM Reply With Quote
Duratec? Its all aliminum so that gets rid of alot of the weight problems that CEC's have, and they are also good for well over 200bhp
ned
posted on 14/12/07 at 04:09 PM Reply With Quote
zetec 1.6se, cheap, small, light (ally), revvy yamaha design head and can go to 170-200bhp on standard internals (+cams) relatively easily. just shell out for the bellhousing and remember exhaust is on drivers side...
Ned.
beware, I've got yellow skin
CaptainJosh
posted on 14/12/07 at 04:21 PM Reply With Quote
What ned said as well the zetec-se engines are fantastic from what i hear
[Edited on 14/12/07 by CaptainJosh]
JimSpencer
Hi
Nice to see somebody's looked up the reg's and figured out Bike and Car engines are often (not always) in different classes in the motorsport world..
If you're going to prep it for Autotests, may well be worth keeping in mind the other grass roots bits too and keep it under 1.7L as that'll give you lots of other places to play (e.g. road going classes at Sprints & hillclimbs) and would certainly help its resale value if you ever wanted to move it on.
To add to the one Ned points out above, could i mention the Toyota 4a-ge?
Perhaps not quite as tuneable as the zetec, but quite cheap to get to 160ish and it's the engine that Raw (Striker's current builder) focuses on.
twybrow
posted on 14/12/07 at 04:47 PM Reply With Quote
What is your budget? How able are you to fabricate/plumb/wire bits for yourself (ie do you need off the shelf parts?)? Are you going for an SVA?
andy_mullin
posted on 14/12/07 at 04:48 PM Reply With Quote
All,
Thanks for the replies, keep them coming. I like the 4age, but it's about 3k from Raw.
The zetec 1.6se sounds interesting what car is it from?
andy_mullin
posted on 14/12/07 at 04:57 PM Reply With Quote
To be honest I can do most things myself, budget is a different matter, I dont want to throw money at it but what ever I do I want it look right and go well. No SVA (at the moment). Off the shelf parts are handy because sometime they are good value for money.
twybrow
posted on 14/12/07 at 05:20 PM Reply With Quote
In which case I would say Duratec or Vauxhall red top. Both will give circa 200bhp with throttle bodies (or even carbs if no SVA). The XE is quite a bit heavier, but much cheaper and the exaust comes out the passenger side. Duratec would be lovely (and getting cheaper all the time) but could be more work to install.
JimSpencer
posted on 14/12/07 at 05:47 PM Reply With Quote
Originally posted by andy_mullin
All,
Ahh well if you're going to just buy one..
Then they'll all come out around that sort of price..
If on the other hand you're going to 'LoCost' one then that's a different kettle of fish.
The Zetec Se is in the Fiesta in 1.6 form (i Think) but it's definatly in the Puma in 1.7 form - which is certainly one a lot of speed event people go for.
[Edited on 14/12/07 by JimSpencer]
j30fos
posted on 14/12/07 at 06:09 PM Reply With Quote
well Im just converting a megablade to Saab turbo power, go on youtube and search for Maptun you'll see loads of saabs getting 3-400 BHP on a standard engine im after 300 BHP ( to start ) best of all is im using the standard injection/ecu/engine and it all mounts together using the VX to type 9 bellhouse
Volvorsport
posted on 14/12/07 at 07:04 PM Reply With Quote
volvo 5 cyl , get the noise with it , exhaust on the right hand side .
2.5 20v 180 bhp out of the box, turbo / NA your choice .
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 14/12/07 at 08:40 PM Reply With Quote
To keep in a sensible buget Ford Zetec silver top 1600, 1800 or 2 litre. Very reliable very very cheap to aquire, only real cost is sorting out the induction side of things.
andy_mullin
posted on 16/12/07 at 10:10 AM Reply With Quote
Thanks to all that replied to me I got some good advise, a special thanks Dave about the Volvos.
I've decided that I'm taking the bike engine route.
Thanks again all and have a good Christmas.
hellier0437
posted on 16/12/07 at 07:36 PM Reply With Quote
if you get a burton power catalogue, at the beginning they go through every ford engine , giving power and tuning figures.
might help
onzarob
posted on 16/12/07 at 08:00 PM Reply With Quote
might help
look here for engine info
http://www.burtonpower.com/technical_1/technical_articles_default.aspx
andy_mullin
posted on 16/12/07 at 08:29 PM Reply With Quote
Well I'm back to a car engine again, it's now between;
A Pinto or a Zetec.
I'll take look at the Burton catalogue tonight.
onzarob
posted on 16/12/07 at 08:38 PM Reply With Quote
I was reading the Westfield blurb last night and they say the choice is difficult between the 2 but both have advantages depending on application.
The Car engine will be a better cruiser and road going car. Also will last longer than a bike engine.
A bike engine give high performance from a lighter package and it most at home on a track not that it isn't any good on the road also the engine do not last so long.
HTH
Rob
posted on 16/12/07 at 10:00 PM Reply With Quote
A Pinto or a Zetec.
starting from scratch, like you are, then it has gotta be zetec.
andy_mullin
posted on 17/12/07 at 10:39 PM Reply With Quote
Zetec it is, I rang around some breakers today, they came back with £200 the other £150.
So I need to source;
clutch(what type)
a 1600 zetec flywheel
a set of carbs
exhaust manifold
Megajolt or omex
Polo Rad
wilkingj
posted on 18/12/07 at 08:32 AM Reply With Quote
OOhh... Tempted to offer you my 2.1 PINTO, with hot cam and twin 40 Dell Orto's, std 4 branch Exhaust, and a type 9 box
I was going to put this in my Viento, but it cried out to me for the V8
[Edited on 18/12/2007 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
andy_mullin
posted on 18/12/07 at 06:39 PM Reply With Quote
Be quick and make me an offer I cannot refuse.
FazerBob
posted on 20/12/07 at 08:52 PM Reply With Quote
Engine
Tell me about your Pinto engine, Geoff. It could be just what I'm looking for.
Bob
Bob
<<  1    2  >>
