| posted on 20/12/07 at 02:50 PM |
halogen work lamp glass?
you know these oval halogen work lamps, similar to this:
Anyone know if and where you can buy the replacement glass?
bonzoronnie
| posted on 20/12/07 at 03:01 PM |
Halogen light glass
The glass on these units are, toughend glass.
I found that out when I got mine with a bit of weld splatter.
I normally go to B&Q or the likes and buy one of thier cheapo lights for the glass £4-£5.
Or you could just fit the B&Q light as is onto your stand.
Ronnie
[Edited on 20/12/07 by bonzoronnie]
James
| posted on 20/12/07 at 03:43 PM |
Screwfix do one for £4.99 that's 500watt.
Just had one delivered that seems pretty good although the lead is a bit short.
James
- Muhammad Ali
| posted on 20/12/07 at 03:47 PM |
i'f rather buy the glas for99p then fork out a small fortune on a complete unit - I suspect that this is what I will need to do.
also rckon getting a glass cut would prove to be more expensive than a new lamp.
Danozeman
| posted on 20/12/07 at 04:26 PM |
I doubt youl get a new glass for less than a fiver which the whole lamps are new.
Dan
gazza285
| posted on 20/12/07 at 04:31 PM |
If you are that tight then just use it without glass.
bonzoronnie
| posted on 20/12/07 at 05:32 PM |
No Glass
Exactly what i done at first.
Soon got pi55ed of paying £1.99, every other week for a new bulb.
You can't cut toughend glass. (unless you want it in kit form)
The glass is first cut then placed into a oven/kiln to be toughend.
Ronnie
Macbeast
| posted on 20/12/07 at 08:17 PM |
Something at the back of my mind says the glass cuts down UV from the bulb. Also. the bulbs are known to explode with glass flying everywhere. I
wouldn't risk running without glass.
bonzoronnie
posted on 20/12/07 at 08:19 PM |
Blown bulb
OHHH yes they can go off with quite a bang
Ronnie
