Paul TigerB6
| posted on 31/12/07 at 10:25 AM |
Wanted - Dizzy for Pinto non vac advance
Hi all
I am looking for a distributor to use on the Tiger Supercat i am building for a friend. Standard Pinto with twin Weber 45's so i need a non
vacuum advance dizzy.
Anyone gone over to megajolt and got one lying around that they want to swap for some beer tokens??
Paul
matt_claydon
| posted on 31/12/07 at 11:48 AM |
I just used the standard one without the vac connected on my Pinto with 40s. Ran and idled fine and made good power.
Paul TigerB6
| posted on 31/12/07 at 12:15 PM |
I thought that the amount of advance would reduce power without the vacuum system operational. Would be interested to hear what others feel so will
open up a thread in the proper section but appreciate your comments.
HAL 1
| posted on 31/12/07 at 12:28 PM |
I've got one for electronic ecu, just three wires on, hope that describes it ok.
| posted on 31/12/07 at 03:28 PM |
Vac advance is essentially an ecomomy device it allows the use of weaker mixtures at idle and low throtle opennings.
Paul TigerB6
| posted on 31/12/07 at 04:17 PM |
Thanks for the replies gents. I'll run with the standard distributor then unless the owner's budget will stretch the extra £100 to
Megajolt.
