tim windmill
| posted on 11/1/08 at 11:23 AM |
savage switch replacemant led bulbs.
Can you buy the red led bulb that is fitted inside the savage switch warning light? I have a brake fluid/handbrakewaring light that for some reason
has started illuminating very dimly when activated,suspected a dodgy earth but on investigation and stripping the switch and removing the bulb it is
the bulb itself that is faulty and not the wiring, So back to the original question can the bulbs be bought seperatley or is it a case of buying a new
warning light switch. thanks
dave-69isit
posted on 11/1/08 at 11:26 AM |
bulbs
try askin chris aka zxrlocost if he not on line try phoning him good bloke he sells a few savage switches
Paul TigerB6
| posted on 11/1/08 at 11:55 AM |
I saw them in Europa when i was there a couple of months back. They do different colours too - not just blue. Think there was red, green, yellow etc
RazMan
| posted on 11/1/08 at 01:37 PM |
They are not bulbs - but LEDs. I tried to find some spares but ended up buying a new switch.
Raz
| posted on 11/1/08 at 01:38 PM |
wozzit this bulb/LED look like? should be possible to make one (see my LED Bulb thread).
if I am thinking fo the same swicth, then they ain't cheap (hence none on my car ) but seems a pity to buy a new one for the sake of a
lamp.
[Edited on 11/1/08 by 02GF74]
Paul TigerB6
| posted on 11/1/08 at 01:44 PM |
Yep - Europa Spares had replacement LED's to fit in the switch. From memory they were around £3 each. Couldnt see them on the website but they
were on the wall next to the counter in various colours including the standard blue.
RazMan
| posted on 11/1/08 at 01:48 PM |
They are tiny leds with built in resistors - about the size of the smallest dash bulbs.
Raz
omega 24 v6
| posted on 11/1/08 at 04:51 PM |
Switches are made I think by a company called APEM and the spec sheet HERE
Shows the bulb type as a midget grooved T1 3/4 filament or led.
They can be found HERE
part no's 42-1030 to 42-1031 only in red and green though.
tim windmill
| posted on 13/1/08 at 11:47 AM |
thanks for all your replies i managed to pick sum up from autosport show, £1 each. so got a couple of extras just in case 2 red , 2 blue. If anyone
finds themselves in the same predicament drop me a line.
jacko
| posted on 13/1/08 at 10:21 PM |
Tim, hanson electrical down boulevard in Hull will have them
Graham
