jimbona2
posted on 3/2/08 at 03:47 PM |
flywheel housing plate
just realised I havent got a flywheel housing plate, probably not the cleverest thing to leave it open to the elements with rocks and all that
potentially going in..
has anyone got a flywheel housing plate going for the 2litre silver top zetec?
let me know how much!
cheers
[Edited on 3/2/08 by jimbona2]
jimbona2
posted on 3/2/08 at 03:53 PM |
current state
SeaBass
posted on 3/2/08 at 05:24 PM |
I made one out of sheet aluminium using the outer profile from the bellhousing and the inner profile / clearance from the original mondeo plate.
Neither the sierra plate or the mondeo/escort will be much use to you I don't think.
big_wasa
posted on 3/2/08 at 06:20 PM |
^^^ as above even the sierra cover will leave a gap.
easier to make one
Mole
posted on 3/2/08 at 06:21 PM |
I got one off ebay and it was actually off a five speed capri. A fair bit needed to be cut out of the middle and another bit welded into close a gap
on the drivers side. The original one off the mondeo is a different shape altogether to fit a different box.
[Edited on 3/2/08 by Mole]
Mole
posted on 3/2/08 at 06:38 PM |
Never took a photo before I fitted it I'm afraid. I also had the flywheel on already so I had to cut it in half.
paulf
posted on 3/2/08 at 08:09 PM |
I just made up three seperate 1.5mm alloy plates to fill the gaps .
Paul.
