| posted on 7/2/08 at 12:10 PM |
22 mm I.D. aluminium tube?
don;t suppose anyone has got a short length (20 - 30 cm) of 22 mm i.d. aluminium tube lying round and taking up space?
wall thickness not too important as it it not scructureal - looking to make some lamps out of it.
(off to B&Q now but I think they do 20 mm O.D max).
----- partial result; B%Q do 22 mm copper pipe couplers so that may do.
VVVV B&Q do 25 mm steel but much heavier than the copper tube; copper will be handy to dissapate the heat.
I did notcie some short cupboards legs for just over a qid but at 30 mm a bit too big.
[Edited on 7/2/08 by 02GF74]
lsdweb
| posted on 7/2/08 at 01:24 PM |
Aerial pole? B&Q might have 25mm ?
A bit late seeing as you've probably already gone there!
Beardy_John
| posted on 7/2/08 at 07:56 PM |
I have literally tons of ally tube at work, we make aluminium access equipment
Will check and let you know Is the wall deff not important? No bending required?
| posted on 8/2/08 at 09:19 AM |
no.
the internal diameter has to be 22 mm. it is to house some LED lamps - no bending and wall thickness not important as it is not structural; although
thick tubing > 3 mm is going to start to increase weight unecessarily.
ideal 20 mm AF internal hex tubing would be even better but that is dreaming.,
the copper tubes are a very good fit so thankt for the offer but don;t bust your a%% looking - naturally al is prefered but I have a workable
alternative.
Beardy_John
| posted on 11/2/08 at 09:26 PM |
Had a good look round today but all I could find is 25mm ID tube with 1/4" wall. Any good??
lsdweb
| posted on 12/2/08 at 10:13 PM |
B&Q aerial pole is 22.5 mm internal ID.
colt_mivec
| posted on 12/2/08 at 10:38 PM |
Try the link below,Very good service and can get anything
Ebay Link
| posted on 13/2/08 at 08:37 AM |
cheers but that is a touch too big internally.
I'll see if can use the 22 mm couplers.
