r1_pete
posted on 8/2/08 at 08:38 PM |
Escort mk1 or 2 crossflow stat housing wtd
As per title, need crossflow escort / cortina stat housing.
Rgds.
Pete.
[Edited on 8/2/08 by r1_pete]
posted on 8/2/08 at 09:00 PM |
This what your after? £21 form Burton Power.
r1_pete
posted on 8/2/08 at 09:10 PM |
Not quite, it twists the wrong way, I have a ford one the same, means with the raceline water rail the oulet sticks out sideways, I want it to point
forward, so I can extend it with a peice of ally tube.
Cheers.
Pete.
theconrodkid
posted on 8/2/08 at 09:22 PM |
if its the std one that faces towards the back of the engine,i think i have one but its a tad dark in the scrap yard that is my back garden,ill look
in t morning
who cares who wins
pass the pork pies
posted on 8/2/08 at 09:25 PM |
Can you not set it up like mine? Not enough room??
r1_pete
posted on 9/2/08 at 09:43 AM |
I could, but, I'm using the stock mgb radiatior, and the top connection is at the opposite side. So I thought if I could get a housing which
points the outlet forwards I could weld an extension to it to clear the cam pulleys and have a much shorter flexible pipe.
Must admit that set up looks neat, I could do that with an MGB V8 rad, but then the bottom hose will be at the wrong side, easier to sort though.
posted on 9/2/08 at 10:10 AM |
Easy to move to top hose connection in the radiator provided you have enough room in the top header
