andrews_45
| posted on 18/2/08 at 08:14 PM |
Wanted aldon ignition kit
Does anybody have an aldon electronic ignition kit for a Xflow FoMoCo (MOTORCRAFT) that I could buy pls?
Ta
| posted on 18/2/08 at 08:51 PM |
If you get stuck I have a Valencia distributor in my shed. Used one on my old engine to good effect.
andrews_45
| posted on 18/2/08 at 09:04 PM |
cheers mate, i have just had my car rolling roaded so need to leave my dizzy as is, cause of the advance
ta anyway
caber
| posted on 18/2/08 at 09:19 PM |
If you get an Aldon Ignitor you will have to reset your timing anyway as the contact close point is not the same as a set of switch contacts!
Depending on what coil you are running you may be better off with a Luminition, the Ignitor I had in my Range rover V8 self combusted with a sports
coil that I had put in as I had lost the ballast wire when I changed starter motor for a modern type!
Caber
procomp
| posted on 19/2/08 at 09:13 AM |
Hi Carl. Don't worry about the advance it can be reset easily. The aldon setup has not proved to be the most reliable.
There is however at least one company who will do you a new bosh setup with an advance curve more suited to a locost race engine. I will U2U when i
have found his details if interested.
Cheers Matt
andrews_45
| posted on 19/2/08 at 03:17 PM |
cheers chaps, spoke to the guys at luminition, they are sending me an adapter plate to enable me to use my magnetronic kit that I already had
ta anyway
