Kriss
posted on 3/3/08 at 09:48 PM |
Sausage Filter - '03 R1
No way am I having a std airbox. Seeing as I am having Samco's etc it need to be done to "dress" it up a tad and to scare the odd
school girl!
anyone know where I can get one cheap? How do I go about the base plate?
thanks in advance. I dont want to spend more than £70 really just out of principal
bassett
posted on 3/3/08 at 10:01 PM |
Hey Kriss try http://www.mnrltd.co.uk/index2.html comes with the base plate and bang on budget.
Adam
Kriss
posted on 3/3/08 at 10:11 PM |
brilliant. would i need the £70 or £75 one? we both have the same negine dont we?
do you have to cut the base plate to fit? Chris said he could do that if need be.
is it just me or does the pipercross writing look a tad fake?
cheers adam
PAUL FISHER
Foam filters may look great but they are very loud,if your thinking of doing a few track days,a lot of tracks now clamping down on noise,and its going
to get a lot worst at most tracks,a lot of tracks now you have to pass static,and drive by,for this reason MK are now supplying extra quiet exhaust
silencers,and sealed inductions fitted with cold air feed remote cone filters,these are a good alternative if you can't or don't want to
fit the original airbox.
bassett
posted on 3/3/08 at 10:24 PM |
Yeah ours should both be 5PW codes. I dont think it matters on engine anyway just the amount of room you have under the bonnet. The one im fitting is
the 40mm one and its got the pipercross product number C5001. The pipercross writing looks pretty good in the flesh.
PAUL FISHER
posted on 3/3/08 at 10:49 PM |
Here's a picture of the ones like MK now supply,a cold air feed is connected to it with a remote filter.
Guinness
posted on 4/3/08 at 08:12 AM |
Paul,
Is that MK are supplying parts very like the Pipercross one, or just similar.
I have a PX600 back plate with a foam filter on it. I looked into the cost of the genuine Pipercross airbox as shown on the photo, and it was pretty
expensive. Are MK's cheaper / compatible?
Mike
Kriss
posted on 4/3/08 at 09:54 AM |
they look pretyy cool paul, a lot tidier than the std airbox.
any idea on price of these though?
I will give Chris a call later in the week and see what his opinions are.
cheers chaps.
OH, do you have to cut the back plate Adam on the MNR kit?
whitestu
posted on 4/3/08 at 11:18 AM |
These are £136 at Burtons excluding the backplate.
Stu
Kriss
posted on 4/3/08 at 11:27 AM |
A call to Chris and then MNR it is!
Oi, Adam, do you need to cut the back plate or not? if so, what is the best method to do this?
bassett
posted on 4/3/08 at 12:25 PM |
I think the back plate just needs holes made for the throttle bodies using a hole saw but i havent fitted mine yet so cant say any further than that
but im sure its an easy diy job.
Adam
PAUL FISHER
posted on 4/3/08 at 02:55 PM |
Yes its the same by the looks of it,MK keep them as a stock item,just checked with them,they aint cheap though,£220,for the full set
up,housing,filter,feed hose,back plate.
So best to fit the original airbox if you can to keep the noise down
quote: Originally posted by Guinness
Paul,
Mike
colt_mivec
posted on 4/3/08 at 03:04 PM |
Using this for SVA will be out of the question then will it?
PAUL FISHER
posted on 4/3/08 at 03:08 PM |
Cant see any problems with using one though sva,I had a itg foam filter on my 929rry blade and passed sva,so the enclosed housing filter should be no
problems at sva
