13" wheels wanted. 7" wide(ish) and Ford PCD
As the title says.......
I'm after some rims for my PPC£999 car.
The car is RWD Ford based so any Ford fitment will be considered. As will any condition of alloy or steel wheel!
I am (hopefully!!) getting a pair of 215/60/13 tyres to go on the rear and some suitable boots for the front but at the moment they will look silly
plonked around the 5.5" wide rims that are currently holding the car off the ground.
7" minimum sould be OK. I have considered getting some skinny steels banded but I don't have four matching rims that are worth spending
£40 each on having the work done!
Cheap is good as I'm running out of budget to keep the car under £1k!
Located anywhere between Teesside and Derbyshire would be good to keep the travelling costs down!
So, if anyone has anything kicking about, please get in touch.
(I've been offered 3 Capri 7x13s so if you have a spare one to make a set, that could work!)
Cheers in advance.
[Edited on 6/3/08 by owelly]
http://www.ppcmag.co.uk
