JC
| posted on 10/3/08 at 04:09 PM |
Wanted: .75" id tube
Has anyone got a short length (30cm) of .75" id thick walled tube? I need it for seatbelt mounts so it needs to be thickish walled. Beer
tokens in exchange!!!
jabs
| posted on 10/3/08 at 04:54 PM |
What about the 25mm cds used for wish bones thats 2.6mm wall so would give you 19.8mm id. Might have some if it will do
[Edited on 10/3/08 by jabs]
JC
| posted on 10/3/08 at 05:50 PM |
Yes, that would be perfect. It will be cut so actually I'm after 4 x 60mm lengths, if you have any left. Thanks
jabs
| posted on 11/3/08 at 09:02 AM |
What I thought I had and what I have is not the same
what I have is
170mm of 25.5mm od with 2.2mm wall id=21.10mm this is cds
or
250mm of 27.3mm od with 2.8mm wall id=21.9mm this is erw
is this any good
U2U sent
JC
| posted on 11/3/08 at 09:16 AM |
Thanks for looking - the threaded inserts I will be using are 19mm/.75in od so I think your tubes will be too big. The reply/effort are appreciated
though.
