Author: Subject: Wind Deflectors
JimM
posted on 13/3/08 at 08:30 AM Reply With Quote
Wind Deflectors
Want to make my own deflectors but need to purchase the brackets.
Can anyone supply name / phone / web address of shop that stocks the deflector brackets .... ta
[Edited on 13/3/08 by JimM]
Mr Whippy
posted on 13/3/08 at 08:46 AM Reply With Quote
a bit vague there, what kind are you taking about as there is quite a few different styles.
Humbug
posted on 13/3/08 at 08:53 AM Reply With Quote
You can use sidescreen hinges, but that means you still need some way of fixing the wind deflectors so they stay at an angle to the side of the screen.
I would have thought that alternatives are:
making a fixed bracket, something like a piece of angle, but not at right angles if that makes senses, or use these hinges, which can be put on, then tightened up at the desired angle:on fleabay here
Mr Whippy
posted on 13/3/08 at 09:03 AM Reply With Quote
those are the type of hinges I have on my Falcons deflectors, very nice and can cope with the wind pressure easily just by tightening the hinge bolts. Do make sure you use stainless everything.
[Edited on 13/3/08 by Mr Whippy]
JimM
posted on 13/3/08 at 01:33 PM Reply With Quote
Looked thru my kit show pictures and found these ones that are used on Tigers.
tul214
posted on 13/3/08 at 07:41 PM Reply With Quote
Jim
The hinges in your pic are the type supplied by Tiger for use with their doors. The male part drops into the female part shown and would be little use for just a wind deflector. You are better off using the Cobra type as shown above.
Mark
[Edited on 13/3/08 by tul214]
1.6 Raw Super6 sold
JimM
posted on 14/3/08 at 12:39 PM Reply With Quote
Mark,
Thanks for the info and the picture to show how the deflector is fixed to the screen frame.
I checked out you archive photos as well and noted you have a Tiger door as well as deflectors.
Do both the defelctor and door brackets fit the same hole on the screen pillar?
If so, could you measure distance between the hole centres ... means that if I ever get a Tiger door then I can do the same as you and swap betwwen both and use the same hole on the frame.
cheers
Jim
tul214
posted on 14/3/08 at 09:08 PM Reply With Quote
Jim,
Thats correct...same holes. Will post the measurements tomorrow afternoon as I am doing this in the morning
http://www.driving-experience-uk.co.uk/pages/ultimate_supercar
1.6 Raw Super6 sold
tul214
posted on 15/3/08 at 04:56 PM Reply With Quote
Jim,
Dims are as per pic...
20mm from top of frame to 1st centre
145mm between centers
If you need anything else let me know.
P.S. the 996 was impressive,
the Lambo was disappointing
the Ferrari 360 was nice
the Aston was big and heavy
the Elise was fun.
1.6 Raw Super6 sold
