Author: Subject: wanted
iceman26
posted on 27/3/08 at 11:31 PM Reply With Quote
wanted
hi i need a bit of round solid alloy about 10mm dia to make gaer leaver has any one
got about 6" or can let me know were to gat some from
thanks
worX
posted on 28/3/08 at 06:18 AM Reply With Quote
These guys are really helpful
http://www.metalfast.co.uk
posted on 28/3/08 at 07:54 AM Reply With Quote
pretty sure B&Q do 10 mm solid aluminium rod, will it be strong enough?
they also do larger diamer aluminium tube.
Davey D
posted on 28/3/08 at 08:16 AM Reply With Quote
a 10mm aluminium rod will bend quite easily. if it has to be 10mm id go for stainless.. otherwise you need something a bit fatter if you deffo want aluminium
RazMan
posted on 28/3/08 at 09:35 AM Reply With Quote
That'll bend on the first gear selection - stainless tube will be better and won't weigh much.
Raz
