austin man
| posted on 7/4/08 at 09:43 PM |
Carb ballancer
Just had to reset my twin 40's does anyone in the Rotherham area have a carb balancer I could lend ???? to ensure correct air flow
a gas analyser would also be nice (pushing it a bit me thinks on that one)
| posted on 8/4/08 at 07:26 AM |
Using a tube as a stethoscope works better on twin DCOEs than a carb balancer.
Trick is to hold the end of the tube at exactly the same relative position for each venturi.
| posted on 8/4/08 at 07:54 AM |
I used a length of hose to balance my 4 bike carbs - when I eventually used the proper tool I found that I'd got pretty close with the
hose-in-ear technique. Not exact, but not too shabby either.
Backfires make you jump though!
[Edited on 8/4/08 by David Jenkins]
r1_pete
Do the carbs have vacuum take off's? if so I have a set of gauges for balancing bike carbs... S26 area very close to you.
| posted on 8/4/08 at 08:23 AM |
car balancer - listen for an even beat in the exhaust and you have it right.
austin man
| posted on 8/4/08 at 08:10 PM |
carbs
hav tried using bike carb balancer but dont have vacum take off these balancers caused the carbs to flood. Thanks all the samew. Looks like ear to the
ground then
