Shamrock GS
| posted on 4/5/08 at 02:25 PM |
Type 9 box to chassis bolt and cup washer wanted
I am looking for the cup washer and bolt which connects the back of the gearbox to the chassis - mine fell off!
Failing that can anyone tell me the size of the bolt? Its not 10mm.
Beer tokens waiting
Gary
[Edited on 4/5/08 by Shamrock GS]
Sun Tzu, The Art of War
| posted on 4/5/08 at 07:10 PM |
I'm sure mine is held in with M12 bolt. It was too mobile with just the original cup washer so I fitted an oversize washer inside it and it
cured the play. A piece of thick plate with a hole drilled for the bolt might do the job.
Shamrock GS
| posted on 4/5/08 at 07:50 PM |
Is the cup washer needed? I am not sure how much movement there should be or how tight to do up the bolt? - any words of wisdom?
G
Rosco
| posted on 4/5/08 at 11:06 PM |
I couldn't see the purpose of the cup either. No doubt there is some on a Sierra but it doesn't appear to do much on a kit.
Before you ask, I did fit it anyway, just for competeness.
Bluemoon
| posted on 5/5/08 at 07:53 AM |
Not sure about the purpose of the cup, but it would stop the gearbox pulling through if the mount failed.. Ford mist have a reason for fitting
it???
Dan
| posted on 5/5/08 at 06:06 PM |
I may have the cup washer at work ,the bolt is 12 x1.5 iirc
flak monkey
| posted on 7/5/08 at 06:49 AM |
Mines just bolted in with a M12 bolt. No problems yet...
Sera
http://www.motosera.com
Macbeast
| posted on 7/5/08 at 07:48 AM |
The cup washer might allow the gearbox to self-centre on the mount ?
| posted on 8/5/08 at 05:50 PM |
You have u2u
