Author: Subject: Suzuki T/B parts
scutter
posted on 6/5/08 at 05:50 AM Reply With Quote
Suzuki T/B parts
Gentle folks, What is the correct term fo the springs and plastic cups that are circled in the picture above?
I got the station welder to seal up all the unused ports and bosses in my throttle bodies ready to fit to the car and the heat has melted the plastic cups making them unusable
Also does anyone know of a good palce to get the said items, I don't fancy paying Suzuki GB prices?
Many Thanks Dan.
clairetoo
posted on 6/5/08 at 05:57 AM Reply With Quote
Looks like your welder killed those I`m sorry to say - if they are available as spares then suzuki is probably going to be the only place to get them
PS - why weld ? The normal thing to do is just press or glue a bung in there ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
theconrodkid
posted on 6/5/08 at 06:33 AM Reply With Quote
bushes Dan bushes,or more like toasted bushes.
doubt you can get them or get the bods apart,best to look for a new set,try Malc at yorkshire engines or the bay of flea and use metal mend or similar to fill the holes
who cares who wins
pass the pork pies
scutter
posted on 6/5/08 at 07:21 AM Reply With Quote
Until I forgot to strip down the T/B's, welding them up was the easiest solution, free/quick and as someone else did it painless.
I'll give the Suzuki dealer a ring once I know what i'm asking for.
ATB Dan.
Dusty
posted on 6/5/08 at 09:59 AM Reply With Quote
Butterfly spindle bushes?
ruudbeckers
posted on 6/5/08 at 10:07 AM Reply With Quote
Have a look here for the suzuki part numbers and names:
http://www.flminisprints.com/tech/Suzuk_GSX_R750_Microfiche_2000_2003.pdf
clairetoo
posted on 6/5/08 at 04:27 PM Reply With Quote
I didnt see them on there - so that would probably mean their not available as a spare part .
I think there is allso a seal behind the spring/bush setup which will probably be fried as well...............
Claire xx
