Mr Whippy
| posted on 6/5/08 at 12:14 PM |
Wanted Pinto tube manifold
After one of these, I’ll take an unwelded one also so long as it has the manifold plate, needing one that does not go straight out the side of the
bonnet but more like a standard 7 type. Photos of it would help but I have a bit of room to spare, well apart from the column being always in the
way…
Thank you
DaveFJ
| posted on 6/5/08 at 01:59 PM |
I have the beginnings of a manifold....
It's 12mm thick ally plate and was cut in the good old fashioned way - with a hole cutter in a drill press....
not particularly brilliant and needs some cleaning up but the holes are reasonably well lined up...
yours if you want it....
Dave
Mr Whippy
| posted on 6/5/08 at 02:37 PM |
you have u2u incase you hadn't noticed
