Author: Subject: Wanted - borrow spring compressors, lincolnshire
JC
posted on 20/5/08 at 04:15 PM Reply With Quote
I bought some spring compressors but they don't fit the 2.25" springs I am using. Does anyone in the Lincoln-Newark-Sleaford have a set that I could borrow that fit this size spring please??
nitram38
posted on 20/5/08 at 04:19 PM Reply With Quote
Why do you need compressors for coil overs?
You simply slide them on the shock, put the collet on and screw the ring up.
MikeR
posted on 20/5/08 at 05:14 PM Reply With Quote
some people have acquired springs that are just a little too big for the shocks (like me).
My plan is to fit the shocks at the front, get the g/f to stand on teh car and tie wrap the shocks closed.
I'll then remove the shocks (carefully)
remove the spring (very carefully)
and wonder how the heck i'm going to remove the tie wraps without errr indoors asking the question "is that safe?".
r1_pete
posted on 20/5/08 at 06:08 PM Reply With Quote
Just be carefull how you ask....... I can just imagine my Mrs. answer to "put some weight on ere love."
P.S I've got some compressors, but think they're only good for standard tintop springs, will post a pic in a bit, will be at Newark Barge tomorrow night on the bike weather permitting....
r1_pete
posted on 20/5/08 at 06:16 PM Reply With Quote
r1_pete
posted on 20/5/08 at 06:17 PM Reply With Quote
JC
posted on 20/5/08 at 07:16 PM Reply With Quote
Pete, yes, those are very similar to the ones that I have!
I like the adapted device though!
I did indeed buy springs 'slightly' too long for my shocks (well, struts actually). They were an ebay 'bargain'!
daviep
posted on 20/5/08 at 07:34 PM Reply With Quote
I've recently given up using spring compressors completely, I now use a pair of 1" ratchet straps. They are so quick and easy you wouldn't believe it.
daviep
posted on 20/5/08 at 07:35 PM Reply With Quote
I've also bound the coils together with mig wire in the past!
JC
posted on 20/5/08 at 07:38 PM Reply With Quote
OK, new post title.. wanted, ratchet straps........!
dave r
posted on 20/5/08 at 08:10 PM Reply With Quote
pillar drill and cable ties
use the normal 4 or 5mm ones, not the heavy duty police handcuff type.. they let go!
