skidude88
| posted on 8/7/08 at 12:56 PM |
Large(ish) rivets 5.5 x 16mm
Removed fuel sender from plastic tank which had been riveted on.
Holes in tank are 5.5mm (7-32 in old money)
Tank and sender (standard lever arm) depth is 14mm
Tried local suppliers and the wibbly-wobbly-web = no joy
Only need 6!
Must exist 'cus I've just removed 6!
One supplier could get 6mm's, but £91 a bag (or sack!?)
Can anyone help?
Early MK de-Dion CBR1000 FJ-FP.
Mr Whippy
| posted on 8/7/08 at 12:58 PM |
car builder solutions sells special rivets in smallish amounts, £2.50 for what you need
http://www.cbsonline.co.uk/rivets-409-c.asp
[Edited on 8/7/08 by Mr Whippy]
r1_pete
| posted on 8/7/08 at 01:01 PM |
Sure I've a bag of 7/32, not sure what lengths, will look when I get home, you are talking straight forward pop rivets aren't you?
You're welcome to a handfull in the post if they're what you need.
[Edited on 8/7/08 by r1_pete]
ReMan
| posted on 8/7/08 at 01:17 PM |
I suppose technically that the sealed end type would be preffered, else you could have 6 small holes for the gold to slosh out of
skidude88
| posted on 8/7/08 at 01:33 PM |
I dont think CBS 5mm's will expand enough to the 5.5mm hole and grip, probably pull straight out.
Colin.. 6 small holes to loose gold from is an improvement on the previous large one
| posted on 8/7/08 at 01:41 PM |
There isn't a hole they leave the ball end of the stem in, that's what makes them pop. 5.5 is a big rivet, have you got a riveter that
will take the stem size? I have some 6.4x12 with a 4mm stem
Myke 2463
| posted on 8/7/08 at 01:42 PM |
Hi. 5 x 16 any good ? if so u2u address,
Mike
