Author: Subject: Wanted cut and welded sump 1.8 CVH for Roadster
AdrianH
posted on 15/7/08 at 09:16 PM Reply With Quote
I have spent a few hours over two evenings cutting down the sump, trying to remove the rust and paintwork and after 3 attempts to try and stop leaks I give up.
It will serve to as a guide so I can mount the engine in the chassis over the next few weeks, but the prospect of leaking oil all over the place is just to much.
When the welder hit a rust spot it just blasted through the metal and I found my self chasing a hole.
Can anyone recommend someone who can supply a cut and welded sump.
Adrian
________
[Edited on 15-7-08 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
worX
posted on 15/7/08 at 10:26 PM Reply With Quote
U2U sent
AdrianH
posted on 15/7/08 at 10:52 PM Reply With Quote
Thanks for that wonderful offer Steve. Now to find a good replacement sump.
Adrian
welderman
posted on 16/7/08 at 07:29 AM Reply With Quote
your not far from me if your stuck
Thank's, Joe
I don't stalk people
