Author: Subject: Wishbone maker
saigonij
posted on 13/8/08 at 01:42 PM Reply With Quote
Wishbone maker
Is anyone good at making wishbones?
I want to ask someone if they can make me a pair of wishbones ( wide track ) that are 2cm shorter?
the reason being is that my current setup ( luego ) gives me too much positive camber. I want to have the tops remade so they are 2cm shorter - hence giving me more negative camber.
Id much rather do this than make the bottom wishbones longer - although that might be an alternitive.
anyone help me please?
posted on 13/8/08 at 08:44 PM Reply With Quote
Could you cut your present ones and get them redone? It would save looking for tubing, bush tubes and threaded tubes.
