Author: Subject: Ball-ended thingy
Macbeast
posted on 24/8/08 at 07:45 AM Reply With Quote
Ball-ended thingy
I want to connect Sierra throttle cable to my accelerator pedal. Sierra has pressed in ball connector
I would like to use similar but with 6mm thread
Does anybody supply these ?
ReMan
posted on 24/8/08 at 07:59 AM Reply With Quote
http://www.igus.co.uk/wpck/default.aspx?PageNr=2469&CL=gb-en
Any good?
jollygreengiant
posted on 24/8/08 at 08:00 AM Reply With Quote
Isn't the ball diameter about the same as the ball stud that is used to connect the gas struts on the tail gates. They unscrew and come with the donors (also fitted on many other vehicles with tail gates).
Hope this helps.
posted on 24/8/08 at 08:37 AM Reply With Quote
Weld the piece of the Sierra pedal with the ball to your pedal.
posted on 24/8/08 at 10:28 AM Reply With Quote
Didn't the Rover V8 SUs use a similar ball joint?
