AdrianH
posted on 16/9/08 at 09:53 PM |
Looking for CVH 1.8 sump & poss sierra column cowl
I tried a month or so ago and thought it worth while asking again, if anyone has a Sierra 1.8 CVH sump. Either unmodified or I guess modified if it
will fit in chassis.
Hopefully Steve on here may still be up to use his welding skills?
I also just changed from adjustable steering column to fixed and need the correct cowls, perhaps someone needs to do a swap in the opposite direction?
Just a thought.
Adrian
Why do I have to make the tools to finish the job? More time then money.
UncleFista
posted on 17/9/08 at 09:43 AM |
I don't suppose you travel to Bradford for any reason ? 'Cos in Queensbury (near Bradford) there's this place;
It's an old Petrol station with a couple of half assembled MKs inside. He seems to be buying every Sierra in the area that comes up for sale.
I've bought a starter from him, if you want him number I can get you it, I'll just need to go for a bit of a drive to get it
Tony Bond / UncleFista
AdrianH
posted on 17/9/08 at 08:56 PM |
Hi thanks for the response, no, please don't go out of your way. There seems to be several breakers advertising sierra through out the UK if I
get chance I will phone around this weekend and see what I can get.
Or even have another go at my own sump, or see if worX still fancies having a go!
Thanks again
Adrian
