Author: Subject: M6 U Nuts
posted on 9/10/08 at 11:30 AM Reply With Quote
M6 U Nuts
I'm desperate for a couple of M6 U-Nuts. Don't suppose anyone has a couple spare do they?
This type of thing;
Phil
jimgiblett
posted on 9/10/08 at 12:12 PM Reply With Quote
I havent got any but can't you just make up a pair out of srtips of steel/ally and rivnuts?
- Jim
bram boekestein
posted on 9/10/08 at 01:37 PM Reply With Quote
You can just buy them at your local hardware shop proboarly, here in the netherlands you can.
gr bram
tegwin
posted on 9/10/08 at 01:48 PM Reply With Quote
Its a trim clip...
Halfrauds do them!
www.verticalhorizonsmedia.tv
posted on 9/10/08 at 01:54 PM Reply With Quote
Usually called a speed nut or spire nut several different types exist
examples
http://www.amazon.com/b?ie=UTF8&node=16410081
[Edited on 9/10/08 by britishtrident]
DarrenW
posted on 9/10/08 at 02:01 PM Reply With Quote
Ive got some that look similar at home but called semi units, also have the corresponding hex head bolts that match. Let me know if you want some and ill dig out and post.
posted on 9/10/08 at 04:54 PM Reply With Quote
They don't appear to be speed nuts, spire nuts or trim clips. (According to my searching)
The ones I'm after have a threaded lug. Are these called lug nuts?
Phil
Like these
[Edited on 9-10-08 by Hellfire]
bram boekestein
posted on 9/10/08 at 07:24 PM Reply With Quote
I know modern scooters use them for the bodywork so maybe a scootershop can even help you.
greetz,
Bram
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 9/10/08 at 07:34 PM Reply With Quote
Hi Phil
Think i have 2 or 3 5mm ones that came with my westfield rear lights but the lug is slightly crimped to stop the bolt coming undone.
Anygood???
Can get a pic if need be
posted on 9/10/08 at 07:38 PM Reply With Quote
Thanks for the offer Craig but I'm after M6's
Phil
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 9/10/08 at 07:39 PM Reply With Quote
Will have another rummage tomorrow
