Author: Subject: A bit of help from a plumber
stevebubs
posted on 12/10/08 at 07:36 PM Reply With Quote
Is anyone here able to bend up a 2 inch piece of chromed 15mm copper pipe so that it has a 1 inch offset (like an S bend)
Something like this then pic below.
Trying to plumb a towel radiator in at my dad's and there isn't enough room to install standard compression fittings to do the job. Rescued attachment pipe.JPG
posted on 12/10/08 at 07:49 PM Reply With Quote
dont think you will manage such tight bends without deforming the ends so you cant join to it. Your best approach might be using a street elbow, ie male to female. Dead easy to soldier if you get solder ring fittings.
posted on 12/10/08 at 07:50 PM Reply With Quote
like this:
http://www.screwfix.com/prods/88168/Plumbing/Solder-Ring-Fittings/Yorkshire-Solder-Ring-Street-Elbow-YPS12S-15mm
adam1985
posted on 12/10/08 at 07:55 PM Reply With Quote
no chance only way is like said above really then paint it if you want
stevebubs
posted on 12/10/08 at 08:13 PM Reply With Quote
Bugger.....Using this link
http://www.ciphe.org.uk/student/pipebend.pdf
and a bit of trig leads me to a magic figure of 86mm for the length of pipe and then you have to add tails for connection (10mm each end roughly)
Was hoping there would be a trick somewhere...
posted on 12/10/08 at 08:28 PM Reply With Quote
i think it would be the radius that made it impossible. My bender makes curves about 3 or 4 inch radius, you need more like an inch.
jacko
posted on 12/10/08 at 08:34 PM Reply With Quote
How about cutting the pipe and tig welding ?
mr henderson
posted on 12/10/08 at 08:38 PM Reply With Quote
Plastic pipe?
stevebubs
posted on 12/10/08 at 08:42 PM Reply With Quote
Originally posted by mr henderson
Plastic pipe?
On show so needs to be chrome....
tootall
posted on 12/10/08 at 09:18 PM Reply With Quote
i have i old school pipe bender its like a tightly wound spring u slide it inside then bend it over your knee or something like it. it would help to warm it up over a soft flame to softern the copper it stays really soft even when cool then hardens off over time (days weeks etc) then u could make those close bends then cut to legnth
some people dream of sucsess, others just get on and do it !!
posted on 12/10/08 at 10:23 PM Reply With Quote
Do it in copper then paint it with some chrome aerosol paint. It looks good enough to use in a bathroom.
stevebubs
posted on 12/10/08 at 11:28 PM Reply With Quote
I have a pipe spring - was going to try sticking it in the workbench and vice and forcing the bend....
Also thought about packing with sand/salt and then forcing it in a similar manner...
heating it to make it more plyable would surely discolour the chrome, though...
[Edited on 12/10/08 by stevebubs]
adam1985
posted on 13/10/08 at 11:06 AM Reply With Quote
from any time ive seen them springs being used they dont seem to get the bend as tight as a pipe bender
