Author: Subject: looking for some cossy bits
KAMBO
posted on 29/10/08 at 06:03 PM Reply With Quote
i'm after the following bits
rear disks..calipers and hubs
front....same.........
bolt on driveshafts...rear
L.S.D
SET OF COILOVERS
mcerd1
posted on 29/10/08 at 06:14 PM Reply With Quote
2wd or 4x4 ??
KAMBO
posted on 29/10/08 at 06:30 PM Reply With Quote
SORRY 2WD
mcerd1
posted on 29/10/08 at 06:49 PM Reply With Quote
so that means your after:
*the solid disc type rear calipers - the same as normal sierra's (i.e. any V6 or non-cossie 4x4 as well as any normal model with ABS)
*the front hubs, rear hubs, diff and driveshafts are 2wd cossie only as far as I know (i.e. 7.5" LSD with 108mm CV joints and hubs to suit, front hubs to suit the 4 pot iron brakes)
out of all that I might have a set of the 4 pot iron front calipers avalible soon, but they'd need rebuilt and the weigh about the same as the moon
I take it this isn't for a kit/ locost if you need the cossie front hubs ?
if it is for the kit/ locost wouldn't you be better off with the lighter bits from the standard sierra ?
[Edited on 29/10/08 by mcerd1]
Russell
posted on 29/10/08 at 07:09 PM Reply With Quote
Got some brand new rear vented discs and calipers for non-cossie Sierra rear hubs. Can't remember the size and full spec but will check if you are interested.
I'm a bilingual illiterate. I can't read in two languages.
tasmin289
posted on 29/10/08 at 10:50 PM Reply With Quote
I've got most of the parts you require.
PM me for further info.
Paul.S
