Very much WIP
Jon Ison - 15/4/10 at 07:30 PM
But will this get enough cold air in, dont panic its having a coat of fresh paint once bonnets complete.
rsmith95uk - 15/4/10 at 07:34 PM
Yep - should keep the pedal box nice & cool
Cousin Cleotis - 15/4/10 at 07:35 PM
Looks good, but not really the correct way to use that particular air intake, from what i have read in a couple of books, never used one myself. Its called a "NACA duct" for anyone wanting to research.
Paul
MakeEverything - 15/4/10 at 08:02 PM
So? If it works, and its safe, then its all good id say.
Looks ok to me. Good work cutting it in so well.
Cousin Cleotis - 15/4/10 at 08:15 PM
Originally posted by MakeEverything
So?
A different design or placement might work better, thats all........... My comment didnt really need clarifying, pretty basic use of the English language, or so i thought.
Like i said, looks good, good compromise between form and function?
Paul
MakeEverything - 15/4/10 at 08:23 PM
Paul
Someone's tired!
Not quite sure why you say not correct though?
[Edited on 15-4-10 by MakeEverything]
MakeEverything - 15/4/10 at 08:37 PM
Cousin Clitoris,
Yes, youre right. Ferrari got it wrong too.
Confused but excited. - 15/4/10 at 08:37 PM
Paul
For those that don't want to do the research, it could possibly be called a 'KNACKERED duct'.
Personally I think it looks
Cousin Cleotis - 15/4/10 at 08:42 PM
I did not comment to put down someone's work, it looks like a job well done. but the question was, will this get enough cold air? This is a technical forum?
NACA ducts have to be made to a strict set of dimensions and positioned on panels as flat as possible and so that the air flows over them and not into them, the air will flow into them because of the shape. It looks like a NACA duct but will not function as one.
A different design intake may work better.
MakeEverything, I can assure you I'm not tired my bed time is not until 10pm. I don't have a great way with words and often may seam short and sharp, that's just the way I write. The "So?" and "Someone's tired!" comment make me feel a little attacked, for no just reason that I can see. I thought this thread was started to discuss the air intake on this discussion forum.
Paul
Cousin Cleotis - 15/4/10 at 08:45 PM
Cousin Clitoris,
Did they? Positioned on flat panels? Yes. Air flows over the duct? Yes. The hole in the back of the duct is square not round? Yes.
Locost NACA Duct, Positioned on flat panels? No. Air flows over the duct? No. The hole in the back of the duct is square not round? No.
Paul
MakeEverything - 15/4/10 at 08:46 PM
Paul
Ok, ok, Sorry Paul. I wasnt attacking, rather thought i was defending what seemed like a snipe! Truce!!
The NACA duct or NACA scoop is a common form of low-drag intake design, originally developed by the National Advisory Committee for Aeronautics (the precursor to NASA) in 1945. When properly implemented, it allows air to be drawn into an internal duct, often for cooling purposes, with a minimal disturbance to the flow. The design was originally called a "submerged inlet," since it consists of a shallow ramp with curved walls recessed into the exposed surface of a streamlined body, such as an aircraft. It is especially favored in racing car design.
Prior submerged inlet experiments showed poor pressure recovery due to the slow-moving boundary layer entering the intake. This design is believed to work because the combination of the gentle ramp angle and the curvature profile of the walls creates counter-rotating vortices which deflect the boundary layer away from the intake and draws in the faster moving air, while avoiding the form drag and flow separation that can occur with protruding inlet designs. This type of flush inlet generally cannot achieve the larger ram pressures and flow volumes of an external design, and so is rarely used for the jet engine intake application for which it was originally designed, (the North American YF-93 and Short Sherpa being exceptions.) It is, however, common for engine and ventilation intakes.
Jon Ison - 15/4/10 at 08:55 PM
oooerrrrrrrr.
I only cut an hole.
The way I see it is like this, its a 7, not a lot of bodywork to play with and as its hand made by moi none of them are gonna flat so.......
Do I leave the air intake under the bonnet to suck in hot air that's flowing through the rad or cut a hole and let it pull a bit of cold in, I'm pretty sure 4 pistons spinning at 11000rpm will suck hard enough ? Oh and with a bit if gobo n paint I think it will look ok to.
What is the best way to feed cool air directly to a airbox, particularly given the tight bodywork restraints of a 7 clone ?
boggle - 15/4/10 at 09:09 PM
looks good and i think it will work well as a ram air feed......
Jon Ison - 15/4/10 at 09:17 PM
Don't worry, Ive come up with a better (light hearted) solution, just need to cut a hole in back to feed air box, of and sit on a big cushion to see over it............
Serious question to those in the know, what is the best way to get a cool air feed into a forward facing air box like the set up I have ? Rescued attachment bin.jpg
Cousin Cleotis - 15/4/10 at 09:27 PM
I think NACA ducts do look good, but would be difficult to get to work right, plan on visiting a wind tunnel? They are designed for low drag intakes, not for ram air, as fitted to most motorbikes.
Getting the shape right is easy, how big to make it? no idea. Where to put it? Probably on the front of the bonnet, Its flat and air would flow over it.
I would probably leave the intake where it is but change the shape for better ram air design. Dont know what shape though.
Paul
[Edited on 15/4/10 by Cousin Cleotis]
owelly - 15/4/10 at 09:32 PM
To know if the duct will work as intended, you need to put some wool 'tell tails" in the duct at the mouth and a bit further in. Try shrouding the duct in various places with modelling clay (plasticine) to disrupt the air flow to see if that make it work better. Roundy fronted cars do strange things to air flow and we all know that air passing over a panel will create a lower pressure than that of the still air under it. That's why your hair gets sucked up through a sunroof (if you have hair, and a sunroof that is open). I was suprised to find that , at above 30ish MPH a flappy sticker was getting sucked from the front edge of my bonnet, forwards and down into the grill. When I made the bonnet a tighter fit on the front edge, the sticker would blow up and backwards as you'd imagine it should do.
[Edited on 15/4/10 by owelly]
brianthemagical - 15/4/10 at 09:44 PM
On a car with drag of a seven, a duct is highly negligible.
For the best ram air effect, and thus the most effective intake, a vertical hole incident to the flow is best.
If you want it on a surface ~parallel to the flow, then a scoop type duct will work fine. A NACA duct is for use when you need it to be efficient, such that it doesn't affect the boundary layer, or cause laminar flow bubbles and such where they are not needed.
A 'scoop' design will produce the highest 'inlet effect', much like a heavily cambered wing would produce a higher Cl, but where efficiency is concerned neither of very effective.
As for this situation, if it were a pure NACA duct then it may not be as good as it could be, as such the design being similar to a NACA duct does add some complexity and needles work. Saying that, it's already been done, so there's no point changing it but if it were to be done again a simple smoothed and highly radiied hole would be best.
[Edited on 15/4/10 by brianthemagical]
bi22le - 15/4/10 at 10:32 PM
i agree with most that has been said but i think an important point is being missed. This naca thing is not being used as a duct but a cold air feed. There is a massive vacuum being created by the engine voiding the original design. It does however allow the engine to suck premium fast flowing air.
I think its tidy and for a mod that is nice looking and functional, its bob on!
Regarding the supply to the box, i think a flex hose straight to the air box will be fine. Your building a fun car not a cutting edge race car!
Hmmm does look tidy though.
hicost blade - 15/4/10 at 10:58 PM
I think it looks neat, it will give the more of a ram air effect unlike a proper NACA duct although I think it will still be effective. I have a similar ReVerie 100mm 'NACA' duct and I intend to do exactly the same thing.
If I was you I would look at a slightly bigger air box
matt_gsxr - 15/4/10 at 11:11 PM
These ducts are well proven in RGB and work (probably mostly due to direct cool air feed). In this implementation it looks good and should function well.
Regarding ram air, you won't go fast enough for any real significant effects, this has been mentioned a few times before. So there is little point optimising it for ram-air.
marmot0 - 16/4/10 at 03:46 AM
works on my car
rgb front
rgb front
Ivan - 16/4/10 at 06:16 AM
I think it will work just fine - just one thing - the corrugated air pipe has very poor flow charecterisitics causing major turbulance - much better to go for a smooth bore pipe - that will more than make up for any "inefficiencies" in the utilisation of the NACA form
Also don't forget the fact that the air is entering a negative presure in your duct will change the dynamics of the NACA type duct so be content that it will work well - certainly much better than no duct at all.
Oh - and it looks very cool.
Toprivetguns - 16/4/10 at 07:55 AM
I think it looks great. Hard work and with a design set it mind. Well done mate !
D Beddows - 16/4/10 at 08:29 AM
plus it looks a bit like the 'Time Tunnel' which has to be a good thing
gingerprince - 16/4/10 at 09:08 AM
Aren't knacker ducts just for keeping your nutsack cool?
Brommers - 16/4/10 at 12:09 PM
Looks fine to me, I've got a very similar setup on my Fury.
It's not a NACA duct, of course - it may look a little like one, but the geometry's all wrong for a NACA duct and so saying that it's not being used as a NACA duct when it isn't a NACA duct at all isn't particularly helpful IMHO.
All it is, in reality, is a cold air inlet that looks a bit more interesting that a circular hole in the bodywork. But a cold air feed is a good thing, so I think yours will work perfectly well.
seansverige - 6/5/10 at 06:06 PM
Off topic but could I just ask if those are combined main / dipped units? If so, are they IVA friendly and what diameter are they - don't look more than 50-60mm. Thanks in advance
Originally posted by marmot0
works on my car
rgb front
rgb front
