Hi Chaps
I've a set of four off Two Gates Minilites in pretty nice condition. There is another track day or two left in the well used rubber. Centre
caps present and overall they are very presentable wheels. BTW, they are 14" rims.
No too sure the going rate for these so how does £150.00 sound?
Collection from near J12 on M1. I travel round to Maidenhead regularly if that helps?
PM me
Harvey
[Edited on 8/1/12 by carpmart]
DOH!!!!
They are Ford 108 PCD and were used on my Fury. I'll check the offset and get back to you in a min!
6J rims, can't find any offset markings
Hi you can check to off set roughly by,
Placing the wheel on the floor with the rim bit facing the floor,
Put a flat bar across the tyre etc and mess down ro the floor and divide by 2,
The measure from the flat bar to the inside of the wheel ie the bit that has the stud holes,
Then minus this from the halved dimension will give you a rough idea of the order etc if that helps,
Bump!
Make me an offer, I can only say no!
U2U Sent
[Edited on 13/1/12 by ian locostzx9rc2]
Just checked and these are approx 35mm offset
£130 takes these, need the space!
Bump - Final price or I keep em £120
[Edited on 19/1/12 by carpmart]
Now sold, pending collection tomorrow.
Hi I will take the wheels if you dont sell them tomorrow
Trevor
Tomorrow was today and they were collected!
SOLD SOLD SOLD!
