Engine & suspension clearout - zetec headbolts, poly bushes, brackets, rear uprights plus more
clanger - 24/11/13 at 12:58 PM
Brand new OEM Ford Zetec head bolts. 2 x sets plus a few spares
£15 per set delivered:
Pair of Sierra based rear uprights fully TIG welded. Well made, brand new units never fitted. Only 2.2Kg each
£100 delivered.
Set of 12 x poly bushes Sizes are: Tube 19mm OD x 38.3mm long x 12.75ID
Bushes are 34.5mm x 28.8mm x 19mm Diameters / 4.5mm top hat x 17mm overall length
£25 delivered.
Poly bushes on their own x 24 - £15 delivered
Rear upright camber adjuster, as per Haynes Roadster book
£10 delivered
Suspension tubes x 19
33.6mm OD x 27mm ID x 30mm long
£30 delivered
Suspension brackets x 19
40mm wide internally x 30mm bolt center height off base x 40mm wide. Made from 3mm thick steel with 12.5mm hole
£40 delivered
[Edited on 24/11/13 by clanger]
Angel Acevedo - 1/12/13 at 04:14 PM
U2U Regarding Suspension stuff.
