Everyone else is having a clearout so I'll join in...
hillbillyracer - 23/10/09 at 08:45 PM
2 minis, 2 Honda engines with boxes, some coil over springs & Peugeot diesel bits.
All on Ebay.
http://shop.ebay.co.uk/kevsl76/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p3686
[Edited on 23/10/09 by hillbillyracer]
Nash - 24/10/09 at 09:41 AM
Anyone know if the engine will fit in an Indy?
Cheers......... Neil
hillbillyracer - 24/10/09 at 12:51 PM
I dont think it's really of much use in a front engine/RWD set-up as it's one of the Honda engines that spins anti-clockwise.
You'd need an adaptor plate or bellhousing & if you turned the diff upside down it would work but I'm not sure how a gearbox would like being spun the wrong way round.
More use as a front wheel drive or mid engined set-up using the gearbox that comes with it,
It's shame really as Honda have some cracking engines that would other wise be well suited to a lightweight car like a 7.
Nash - 24/10/09 at 01:38 PM
Thanks for that.
So do all FWD (local wheel drive if mid engined) jap engines spin the "wrong way". The reason I ask is I was considering an MR2 engine swap with an adapter plate onto my Type 9 box.
Any / all information greatfully recieved.
Regards.............Neil
hillbillyracer - 24/10/09 at 04:41 PM
I'm not sure but I think it's just Hondas & mabye Mitsubushis & not all of them at that, the Honda K series (nowt to do with Rover) which is in modern Hondas I think spins clockwise.
Toyotas spin clockwise as normal, the 1600 4age engine has ben fitted to quite a few kit cars so there should be plenty of info about fitting them up with RWD, mabye les so about the later 2.0 engine but it'll have been done!
hillbillyracer - 1/11/09 at 04:59 PM
A load of this stuff ends tonight & I've got a couple more bits on now too, Recaro seats & some bike throttle bodies.
