I have finally (long story) dug the megasquirt out and stuck it on the bay here megasquirt and throttle bodies etc ZETEC on eBay
(end time 30-Oct-10 20:33:19 BST)
Happily sell off the bay, make me an offer!
also have a Dunnell ignition ECU. It is mapped (2D) for a 1800 zetec, and when on my zetec gave 150bhp at the flywheel. I later fitted a megajolt so I
could play about with settings, and I never got as good as the dunnell map in terms of power over the rev range or indeed economy (it was in a
spitfire, and at motorway speeds was returning late 30's mpg )
Dunnell will remap the ecu to whatever spec engine you have for a nominal charge, and will happily change to 3D should you want it.
pics in my archive (cant work out how to add them on here )
