For that amount of work, you'll need at least four Polish.
which ends the front!?!
Ha ha na a litre of Kurust and you may be ok! You can only just make out where the headlights would go to the left.
If you dug down a bit there might be some more of it. It looks like it could be used as a cold frame if you found some glass for it.
Originally posted by Confused but excited.
For that amount of work, you'll need at least four Polish.![]()
"Wash your car Boss?"![]()
Im surprised he hasnt tried to maximise it's value with the usual full set of pictures: offside, nearside, frontal, back, engine, drivers seat
and dash.
You never know, a picture with slightly less straw and animal waste might make a difference. If there is a chassis number under all that then there
is always a chance of getting a V5.
Just water the ground and grow a new one!
Easy Fix, wud get new mot but no time.
Awsum breaks
Relly fast
No timewaisters or dreemers.
Low reserve, only £15,000, you bid to by not tirekick.
Less dosh than a Saxo bruv and a well good head turner too init.
