I recently had a mate of mine bring his mk Indy over to my workshop for me to make him a rear diffuser, while I was at it I took a pattern and knocked
up a few more with the remaining aluminium sheet so I've stuck them on eBay and thought one or two of you guys may be interested?
Kit Car Diffuser
Just give me a shout if you're interested
James
Not meaning to dis your work, but they look nowhere near long enough to cover the full underside of the boot section of a seven style car, as that is the whole point in fitting one
Add to that, the fins are the wrong shape. Heres what I mean:
The diffuser is supposed to be the last bit of a flat bottomed car, angles up to create a low pressure
With yours, the fins need to be trimmed to a triangle shape, so the the narrowest area can sit against the floor, and ideally the front area could be
longer
Kinda like this
Sorry
[Edited on 13/9/14 by blakep82]
