Ebay item number 271894830424
Round anodised oil catch tanks, I paid £21 a few months back & thought that was cheap.
Might be worth a look if you are in the market for one.
Been meaning to get one, better than an old 7up can...
[Edited on 9/6/15 by Toltec]
Same here, except my current tank is an old oil bottle jammed in the frame
Cheap, very cheap. I've just bought one to see what its like.
I used the two small inlets for cam cover & block breather, then ì drilled & tapped the lid & fitted one of the larger fittings that came
with it so I could fit a filter on the top, job done !
oil catch tank
bought good spot that for the money you carnt go wrong cheers
These are very good value for money, but do be mindful that they are not the lightest if you are weight watching.
Yeah got mine through, its decent quality but weighs in at nearly a kilo! So won't be going on my sprint car but I'm sure it will be useful for something.
Mine arrived too... Not the lightest of cans, but if I can drop 1kg of weight myself, we'll break even
Mine turned up this morning, in a lovely, violent shade of green...
[Edited on 12/6/15 by Toltec]
Fitted mine earlier this week and used the car for the 1st time today. Drove to work, parked up but when I returned after work, discovered a treacle of oil running along the scuttle... Stupid catch tank is leaking at the bottom! Cleaned it all up and once at home disassembled it all and used as much ptfe tape as it would take... hopefully it is enough to stop that from happening again... if not, it will be "buy cheap, buy twice" time :/
