After a bad day at work
Jon Ison - 14/12/05 at 05:31 PM
I decided too sell these on ebay
7572826739
TimC - 14/12/05 at 05:38 PM
Do you do them in mint flavour?
donut - 14/12/05 at 06:10 PM
You must have had a bad day!!!!!
Mad as a box of frogs
omega 24 v6 - 14/12/05 at 06:23 PM
Can you supply me with holes big enough to bury the annoying feckers I had to deal with today?
One big enough for about 3 Ugly fat useless Barstewards should be big enough. I don't mind putting one on top of the other or side by side. Whatever you have in stock and is cheapest to post would be ideal
dave1888 - 14/12/05 at 08:37 PM
how mad is a box of frogs anyway
RazMan - 14/12/05 at 08:39 PM
That's a hole load of postage too!
Mark Allanson - 14/12/05 at 10:26 PM
If you inadvertantly put the hole in the wrong place, I can supply special grease so you can simply slide the hole to the edge of the panel and slip it off completely. You can then apply a new hole in the correct position.
PS Don't leave discarded hole on the the floor, best to sweep them up as soon as they are dropped.
