Dunno whether it's a bargain or not but there's one sat in the breakers next to work. The engine (nee the car) looks intact from what I can see on the CCTV and hasn't been crunched. The tel number is 01733 (Peterborough) 340655.
Don't suppose you know if it has power steering ?, need to convert the wifes
I used an MX-5 for everything but my engine. Personally--and oc course I'm biased--I think they make a perfect donor. The uprights are very small
and very light.
Have a look at my website. Thought much of the picture section says 'coming soon', it will load if you click it.
--Chris
Can't actually go in as I'm at work. It's a series 1, the one with the popup
headlights, if that's any help? didn't user jag use an mx5 as a donor on his locost....
Most MX-5s do have the power assist. Look on the passenger side of the engine for the pump. If there are two pulleys over there, you're looking
at air con as well.
It's a good donor if you can cope with the IRS.
