DIY Supports in Lidl's on Thursday!
birdii - 27/6/06 at 02:44 PM
http://www.lidl.co.uk/uk/home.nsf/pages/c.o.20060629.p.DIY_Support.ar3
Might be handy to have a pair as chassis stands for early assembly, should be strong enough at 100kg max loading.
Only £3.99 each!
stevebubs - 27/6/06 at 05:13 PM
IS this any good?
http://www.lidl.co.uk/uk/home.nsf/pages/c.o.20060629.p.Angle_Grind er_Stand.ar2
peterriley2 - 27/6/06 at 05:24 PM
all i can say is that the grinder stand came out just after ive finished cutting all the chassis steel- sods law!!
caber - 28/6/06 at 08:46 PM
Angle grinder stand not much good for chassis building only deep enough cut for one or two pieces before you have to change the disk or flip the box section. alos not too good at cutting a tru right angle
Caber
GeoffT - 29/6/06 at 12:44 PM
Just bought a pair of the stands, and they seem pretty good, in fact excellent for the price. They're flat packed of course, so you'll have to spend ten minutes each putting them together. Only 780mm wide so not sure if that's enough for chassis stands, easily extended if necessary though.
iank - 29/6/06 at 09:46 PM
Those halogen lights could come in handy in my cave
Mr G - 3/7/06 at 09:53 AM
