Air Compressor - £69.99
looks like a rebadged Wolf / Craft item to me.
TOOLTEC
· 50 litre tank
· 2hp motor
· 8 bar maximum pressure
· Direct drive
· Oil-filled sump tyre
· Automatic thermal cut-out
· Twin gauges
· Fully controllable output pressure
· Tank drain capacity
· Carry handle
· Wheel for easy handling
· Quick connector to efficiently connect air tools
· Air tools not included
http://www.netto.co.uk/internet/nettog/catalogue/catalogue.nsf/webActiveCataloguePages/1-6?OpenDocument&catid=1
[Edited on 27/6/07 by scottc]
Hmmm, this could be just what I need to get the motivation to finish off a load of rivetting I still have to do. Keep putting it off as my body can only take so much abuse.
Air rivetters rule...*so* much easier you'll wonder what you did without it...
looks the same as the aldi one from while ago, pretty good, only prob is the hose they give you is too small bore,
get a decent bore hose, and they;re spot on
Ray
Ah well... went and got one this afternoon and a few air tools. The tools themselves look identical to the Clarke tools, just a different name on them and about 1/3 price. It seems to run fine but I'll test it out when I get a chance.
