Saw this on eBay & thought it may be of interest to some of you out there.
Link
RD
Those units aren't the most modern (they're based upon one of the first reverse boxes to appear on the "new" BEC scene) and
(unless they've changed recently) have a habit of leaking / breaking....
If I was going to get a reverse box I'd go Quaife...
Then again, if I was going to go for a reverse mechanism I'd go for an electric one....
Do you Know who makes them ?
Apart from Quaife.
Jason
I tried searching but I didn't find much on the topic of electric reverse... are there any drawings or pictures available.
Preferably for an IRS setup...
I can honestly say that I've not seen one of them before. Who makes it?
It doesn't look like a Blackbird Motorsport unit.
Are they seriously sh17e? It's just it's local so if it were any good and got no bids, I'd be tempted - if only to keep for a rainy
day.
A lot of the earlier units leaked oil all over the shop then seized
The units a Eurotech FR2000 reverse box BTW... (not made anymore)
Stuart Taylor did one- not sure if they still do....
a flywheel and a starter motor , with the flywheel clamped in between the output flange on the diff and the driveshaft .
press a button , off ya go .
IRS might get in the way tho .
Errr would think that IRS would make mounting a lot easier since the diff isn't bouncing around!
