just been looking for angle drive components on the maplin website for our uni project and it threw up 600w 115mm angle grinders for £7.99 a piece.
don't know if that's with vat, or if they're available at trade counters, but at that price, i'd reckon it's worth finding
out.
diamond disc sets for £4.99 too. 2x wire brush wheels and 2x diamond discs
tom
**linky**
[Edited on 16/1/08 by indykid]
The cheaper maplin angle ginders fall apart -- the gear box screws vibrate loose -- nothing a bit of Locite won't fix if caught in time before
the gears strip.
The discs are cheap and nasty --- it always pays to buy quality discs the cheaper one don't last, don't cut or grind well and have a nasty
burning smell in use.
I can sell you a 115mm angle grinder for a mere £125 +vat and diamond discs to got with it for £62.51 + vat. Mind you you could cut ya car in half one
handed with this bad boy
P.S They are Hilti so damn good stuff
Originally posted by britishtrident
The discs are cheap and nasty --- it always pays to buy quality discs the cheaper one don't last, don't cut or grind well and have a nasty burning smell in use.
never had a problem with cheap diamond discs though i've never
used an expensive one. Once used a cheap diamond masonry disc to cut an RSJ in half with no problems
